Le Deal du moment : -38%
Aspirateur robot Xiaomi Roborock S7 (version 2021) en ...
499 €
Le Deal du moment : -41%
Pompe Bosch EasyPump avec batterie 3,6V ...
39.91 €
dr mimi
Nombre de messages : 195
Prénom : michael
Mon king motor x2 - Page 2 Empty Re: Mon king motor x2
Dim 24 Juin 2018, 21:06
Michel vu que tu connais aliexpress j ai trouver ça
kit de montage seul losi 5ive
https://fr.aliexpress.com/item/Gas-Motor-change-to-Eletric-Brushless-Conversion-Without-Power-for-1-5-Losi-5ive-T-rovan/32850537931.html?spm=a2g0w.search0104.3.33.3aeb731fxzBFN7&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10068_5722815_10342_10343_10340_5722915_10341_5722615_10696_10084_10083_10618_10305_10304_10307_10820_10306_10821_10302_5722715_10843_10059_306_100031_10103_10624_10623_10622_5722515_10621_10620,searchweb201603_1,ppcSwitch_7&algo_expid=9364e4ae-f1af-42a5-9aa1-6caf5a4482b9-5&algo_pvid=9364e4ae-f1af-42a5-9aa1-6caf5a4482b9&transAbTest=ae803_1&priceBeautifyAB=0
kit complet montage moteur controleur 200 A et 2 batteries 4S 6200mah 45C
https://fr.aliexpress.com/item/NOUVEAU-lectrique-changement-D-huile-puissance-Conversion-kit-batterie-incluse-pour-1-5-losi-5ive-t/32856290175.html?spm=a2g0w.10010108.1000013.1.4d6518441sT7Sb&scm=1007.13339.99734.0&scm_id=1007.13339.99734.0&scm-url=1007.13339.99734.0&pvid=bf83c37b-a2f8-4ba9-8f15-8453ff940476&_t=pvid%3Abf83c37b-a2f8-4ba9-8f15-8453ff940476%2Cscm-url%3A1007.13339.99734.0
kit complet montage moteur controleur 200 Asans batterie
https://fr.aliexpress.com/item/NEW-Electric-Oil-change-power-Conversion-kit-for-1-5-losi-5ive-t-rovan-lt-slt/32859359540.html?spm=a2g0w.10010108.1000014.6.2dba38cfattG71&scm=1007.13338.98644.000000000000000&scm_id=1007.13338.98644.000000000000000&scm-url=1007.13338.98644.000000000000000&pvid=d758cbe2-e0d7-4b66-93fd-3c0830775d37&_t=pvid%3Ad758cbe2-e0d7-4b66-93fd-3c0830775d37%2Cscm-url%3A1007.13338.98644.000000000000000
Mathieu tous court
Mathieu tous court
Nombre de messages : 358
Prénom : Mathieu
Dim 24 Juin 2018, 21:09
Ta oublier le chargeur et la carte de prog
dr mimi
Prénom : michael
Dim 24 Juin 2018, 21:12
Et qui te dit qu il a pas deja un chargeur tu est devin  lol!
Nombre de messages : 380
Dim 24 Juin 2018, 21:16
merci a vous  Very Happy s est vraie s est pas donner pour être ecolo  lol! je v ai voir pour la suite merci encore.
si je l ai pour lipo jusqua 6s
Mathieu tous court
Mathieu tous court
Prénom : Mathieu
Dim 24 Juin 2018, 21:17
Ba on parle de batterie 6s . Il faudrai en charger 2 en meme temps . C est pas tou le monde qui a un chargeur 400w 20ampere cher lui Very Happy
dr mimi
Prénom : michael
Dim 24 Juin 2018, 21:32
De tout te façon c est sur cette configuration il faut 2 batteries 6s 6000 mah en parallèle  ça ferait 12 Ampères d autonomie .
Et puis le mots de la fin écologie mon oeil ton chargeur tu le branche a la prise de courant pour charger donc rien d ecolo  ces d origine nucléaire .
https://www.edf.fr/groupe-edf/espaces-dedies/l-energie-de-a-a-z/tout-sur-l-energie/produire-de-l-electricite/le-nucleaire-en-chiffres
Mathieu tous court
Mathieu tous court
Prénom : Mathieu
Dim 24 Juin 2018, 21:37
Cablage parralele plutot . Un controleur  qui marche sous 12s sa doit etre dans les 500e
Si sa se trouve le mec abitte au bord d un barrage et il la du ju gratuit
Dim 24 Juin 2018, 21:51
Mathieu tous court a écrit:Cablage parralele plutot . Un controleur  qui marche sous 12s sa doit etre dans les 500e
je suis juste a cote d une déchetterie est une usine insinerateur ordure vous voyer le tableau les gars,pas de quoi gratter du jus lol! mal exprimer ecolo non mais moins pollueur  Mon king motor x2 - Page 2 90353 Mon king motor x2 - Page 2 90353
Mathieu tous court
Mathieu tous court
Prénom : Mathieu
Dim 24 Juin 2018, 21:54
C est pour la planete que tu fait , ta bien raison
Dim 24 Juin 2018, 21:58
tropbiendit  mdr.a+
Tchoup baja 5
Nombre de messages : 320
Prénom : jm
Lun 25 Juin 2018, 21:58
Jolie machine
Dim 08 Juil 2018, 13:32
salut la team  Very Happy voici mon king en mode nucléaire,modif support lipo pour gagner quelque centimètre,place photos
Mon king motor x2 - Page 2 20180719Mon king motor x2 - Page 2 20180720Mon king motor x2 - Page 2 20180721
lipo en court de livraison. Twisted Evil
Mathieu tous court
Mathieu tous court
Prénom : Mathieu
Dim 08 Juil 2018, 13:44
Sympa l implantation . Par contre tu met pas de ventilo sur le moteur ???
Et coment tu va faire pour LES batterie , tu va pouvoir rentrer 2 accus la dedans ???
Et sympa l attache cable rouge , sa vien d ou ???
Dim 08 Juil 2018, 14:14
Et sympa l attache cable rouge , sa vien d ou ??? de quel cable parle tu!!
pour les lipo la s est avant modif,apres je peu mettre des 4s 8000mah,pour le ventilo moteur il le vende sans mais prevu de faire quelque choses style refroidisseur ordi
Mathieu tous court
Mathieu tous court
Prénom : Mathieu
Dim 08 Juil 2018, 14:25
Les attaches de cable rouges , celle qui sont sur le support de dif centrale .
Tu va la faire tourner en 8s , wouahhhhhhh . Deja que en 6s sa marche fort mais en 8s sa fait beaucoup la  Very Happy
Et pour les ventilo moteur tu a sa par exemple
Mon king motor x2 - Page 2 Screen14
Dim 08 Juil 2018, 14:35
oui en 8s sa doit envoyer grave,pour le ventilo j ai vu mais un peu de patience sa va venir,les attache origine du diff,les pièce du kit s est vraiment top rien a dire,je mettrai des photos une foi les lipo reçu,la plaque lipo modifier s ont de 170cm par compartiment x2, 4s 8000mah 30c.a+
Mon king motor x2 - Page 2 182146
Mathieu tous court
Mathieu tous court
Prénom : Mathieu
Dim 08 Juil 2018, 14:46
Par contre en 2x4s cablage serie , tu va avoir peut d otonomie tu devrais acheter une palette de batterire  lol!
Dim 08 Juil 2018, 15:05
a moins de passer en 8s parallèle,mais bon faut le chargeur puis emplacement des accu.s est juste pour amusement si je fait 15/20mm tranquille s est tout bon, je te dirai sa une foi sortie,le temps avec.a+
Dim 08 Juil 2018, 20:18
bonsoir a tous  Very Happy suis en train de faire des recherches sur un killswitch pour brushless rien ne dit qu on peu mettre quoi que se soi,peu être que l Electrique le contro doit faire s on travail quoi qui arrive,panne radio voir le résultat  scratch une idée merci a vous .a+
Mathieu tous court
Mathieu tous court
Prénom : Mathieu
Dim 08 Juil 2018, 23:21
Sur certaine telecommande tu a un systeme qui s appel FAIL SAVE si la voiture est hor portee , le servo gaz/frein se met en possition frein . Mais je c est pas si sa va marcher avec le controleur fodrai faire des teste
Si ta telecommande ne la pas , tu pe le rajouter separement
Mon king motor x2 - Page 2 15310810
Lun 09 Juil 2018, 17:22
hello  Very Happy merci a toi ma radio gt3b a ce type de FAIL SAVE ,faut que je fasse essaie une foi les accus recu  content
Jeu 12 Juil 2018, 14:37
hello  Very Happy lipo recu avec essaié pour le moment que la marche at fonctionne inversion des fil moteur+rev sur radio nade Evil or Very Mad faut reprogrammer le contro Mon king motor x2 - Page 2 Icon_twisted carte programmation en cours de chemin.a+
Mon king motor x2 - Page 2 20180724Mon king motor x2 - Page 2 20180725
Mathieu tous court
Mathieu tous court
Prénom : Mathieu
Jeu 12 Juil 2018, 14:51
Ahh sa c moche . Pas pouvoir rouler par se que ta pas la carte de prog  affraid
Jeu 12 Juil 2018, 15:54
normalement sa devrai pas tarder la même en couleur  lol!
Mon king motor x2 - Page 2 100_5718a+
Mathieu tous court
Mathieu tous court
Prénom : Mathieu
Jeu 12 Juil 2018, 16:15
J ai presque la meme . Toujours cher hobbywing mais j ai cell avec le grand ecran . Se qui est bien sur cell la c est que ta le menu inscrit desus . Mais vue que jcomprend rien a l anglais , sa m aiderai pas plus que  boulet
